westpr
Beloit WI
5.7 L Hemi
Hello. For about a year I was going crazy tring to figure out a strange problem where if I hit a bump in my 2014 1500 Hemi the engine would die. It seemed to happen more frequently in hotter weather. No codes. I checked as many electrical connections as possible, replace the mass air flow sensor and crankshaft sensor but didn't help. So I needed new struts anyway so I replaced those and problem solved. Obviously that wasn't the root of the problem but smoothing out the bumps stopped the bad connection from happening I guess.
(2) Another issue where the truck would go into limp mode (wouldn't go over 9 mph), ran rough and several warning lights would come on. Usually happened soon after I started it and drove a short distance. I suspected it may have been the fuel cap because it seemed to happen within a day or so after I filled up. I bought a generic cheap cap which seemed to help some but not totally. Also at this time I discovered that the front gas tank strap had broken off. I got that fixed (SEE BELOW). Also I bought an OEM Mopar gas cap and the problem disappeared so I'm not sure if stabilizing the random and/or the new gas cap solved the problem.
GAS TANK STRAP (BRACKET):
Chrysler realized early on that this was a design flaw where one end would rust and break off so they issued a special 12 year warranty, unlimited mileage. THIS IS NOT A RECALL, SAFETY OR OTHERWISE. When I got it fixed there was no charge. I have attached the warranty letter.
  • Ram 1500 Fuel tank strap extended warranty.pdf
DripJust
Canada Ontario
Regarding you're first problem. You may want to check your fuse connections inside your tipm. I had this issue also and it was from my fuses not seating correctly inside my tipm. Once I gave my tipm a service and corrected the seating issue with fuse associated with starter relay, problem solved.
TJP440
omaha
hemi
On the tank mount fix You might want to look at the following post, it's a bit long but worth your time LINKY :cheers:
