HORN DELAY
HemiLonestar
Navy Badge Coast Guard
MD
I thought I had in the general discussion of the 4th gen section. Maybe you should've just passed on commenting if you didn't have anything positive to add to the conversation.
1. You didn't, hence my comment tagging a mod (it was then moved).
2. MAYBE......you should pay closer attention. One would hope you aren't that detail oblivious in real life. The mantra of "attention to detail" was not hammered into you and it shows lol.
3. The fact that you are just now whining about it 3 months later is hilarious.
4. The fact that you think I might care about your whining is even funnier.
Daw14
South Florida
Be careful , you are being watched . You mess with the wrong woked and will suffer same fate as Wildone . I’m feeling triggered,oh no……
16Ram4x4
Missouri
The air horns will also have their own button to be used separately from the factory horns. I have wired one relay coil paralleled off the factory horns and they all operate together.
The second relay coil has its own circuit power, fuse and button.
Now, here is the fun part the normally open relay contacts of both relays are paralleled together to feed the main power to the air horns compressor.
So to sum it up hitting the normal horn button (steering wheel ) will sound all four horns.
Then, just hitting the second button will only sound the air horns.
crcraft
