How do you remove rear fender liners?
JB1
Houston, Texas
I know it sounds stupid.....but does anyone have any tips on how to remove the rear fender liners?
I removed all the screws including the two near the frame. I could move it side to side, but it was so tight I couldnt get it over the fender lip.
I need to change my shocks.
JB1
JB1
Houston, Texas
are you doing your drop this weekend?....if so please let me know how you remove the rear liner, it seemed stuck behind the lip and wouldnt budge
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Mine gets stuck sometimes too, you basically just have to yank on it until you get one small part out, and then slowly release everything that's stuck, and it'll fall onto the wheel, from there you can lift it up and out.
JB1
JB1
Houston, Texas
pull down first or out?
BlackedOutHemi
DFW, Texas
2012 & 2012
Get it loose first, and then pull it up and out. To get it loose, start at a bottom corner, and yank it out from around the lip, and then continue around.
JB1
JB1
Houston, Texas
Thanks, I'll give it another try. The corners is where it was stuck but I didnt push up first
blackout11
alpharetts GA
2011 R/T
I took a screw driver wrapped a cloth around it it put it under the lip and slid it all the way around the fender under the lip and it came right off can be a reall pain.
quietpeen
2021 TRX
Hellcat
sounds like a real pita lol
SMITHY
KANSAS CITY
2011 Dodge Ram Quad 4x4
4.7 Magnum
I did not remove my wheel liners to do my rear shocks. I cut my wrench in half then I was able to get it onto the inside bolt. It took a longer time but it did work.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
start on one side and work your way up and over...much easier to install then remove, thats for sure.
PoMansRam
East Aurora NY
Bringing back an oldie here fellas and I'm sorry if it's been discussed, but do you think it's necessary to pull the rear fender liners for a DIY fluid film or woolwax treatment? Looking under my 2017 Ram 1500, it looks like you can mostly reach around and above them. Obviously, removing them gives better access. Just trying to talk myself out of it. LOL
Bee1971
Sobieski WI
2011 Sport 4x4
345 Hemi
It’s a ten minute job removing those liners
Jacking up the frame in front of the rear tires makes it that much easier to pull out the rear liners above the tires
I took it a step further when I sprayed fluid film
I removed all the tires / rims so I could get my big melon inside and look
You definitely need to get your spray wand inside the support bracket holes so the fluid gets behind where the bracket is spot welded to the rear fenders / quarters . That’s where the rust starts
I hate rust and the extra attention was worth it still today
Spotless
PoMansRam
East Aurora NY
It literally is a 10min job. I removed the rear liners today before I applied woolwax to my Ram. Also dropped the spare tire. 11 bolts each and the liners pop right out. I removed them as the truck sat and had no issues. The woolwax job took me a few hours. I'm sure there's cavities and spots I missed, but I feel it's much better than the ~$160 Krown job I had done on it last year. Nothing against Krown, it's just I prefer a product I can actually see on the surfaces. I couldn't see any krown after a few weeks.
John Jensen
San Diego County
Ecodiesel
When I did the rear shocks I used a half wrench (like SMITHY above) and cut a hole in the liner to get my socket on the outside bolt/nut head.
When finished I plugged the hole with a rubber plug. Can't tell it's there unless you are looking for it. And next time for rear shocks it will be easy peasy
PoMansRam
East Aurora NY
I thought about doing that for re-sprays. Just drilling a few access holes in the liners and use some plugs to cap them. The liners themselves are simple to remove, it's just over time even though I sprayed and treated all 22 bolts, some of them are eventually not going to play nice. Problem is, you will never get a thorough spray job all up in there without removing them. There's just too many nooks and crannies in and around the wheel well area.
Pocho808
