How Much of an offset on a 2wd
Hemipower392
College Station, Texas
I'm missing 2 cylinders
Hey guys, I've been told by some people that a negative offset can not be done on a lifted 2wd but then I've been told the offset can be as much as you want it to be. The reason I ask is because I'm not very familiar with this and I'm looking to swap rims and tires because I want a more aggressive stance than I do right now running +18's
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
You can run whatever offset you want (within reason) on a 2wd same as you would on a 4wd.
xrsman
Ontario
3.0 Ecodiesel
Yeah what Brandon said, just because you have a 2wd it doesn't restrict you from having a wider offset.
CVX20
Ont,Ca.
2019 Classic Express
Just keep in mind that the farther you offset the harder it is on ball joints.:favorites13:
southalum
