hunterdan
- May 7, 2018
- 1,160
- 1,518
- Location
- SE PA
- 2019 classic
- 5.7 Hemi
I saw there was one thread on these already, but figured I'd post my review.
Coming from a set of form lights, I had mild expectations for these, especially at the $300 price point. Well, color me impressed, because these things perform as well, if not better than the forms do at less than 1/3 the cost. Jury is still out on the longevity. But it's sure a lot easier to swallow replacing a set of $300 lots than $1100 lights. The styling is a bit different, fit and finish is on par with alpharex lights I've had, which isn't terrible.
So, these are full LED, meaning no bulbs to replace. Everything is integrated. One projector is a bi-led projector for low and high beam and the inside projector is high beam only. They come with an adapter harness installed to adapt quad/dual lights to the projector style plug. And includes a pigtail for the drl that you can run to the fuse box, as well as an extra set of pigtails that are used if you have quad/dual lights (I'm assuming this goes to some kind of resistor). The instruction booklet is actually pretty detailed, far better than most other lights I've gotten. I don't know who Partsam is, or where they came from, but if I were alpharex and some of the other manufacturers, I'd be worried because these things actually perform.
So, I didn't get the drl hooked up since I have a dedicated drl circuit run on my truck. I have to swap the plug end out for a different end, and didn't get to it. I'll probably do that tomorrow since I already the plugs for it. These do have a startup sequence, but again, I believe since I don't have the drl circuit hooked up, it's not activated on these at the moment. But, the sequential turn signals and everything else are functioning and so far no issues. I will say, there is a sharp cut off line, without a slope. The pictures I'm going to attach literally don't do these lights justice as the camera turned down the brightness by a lot. The high beams are insanely bright. Probably the best high beams I've had out of a set of lights this far. Especially aftermarket lights.
