How to Add Automatic Temperature Control (ATC) to a Manual Temperature Control Truck
bhiii
#justsaynotochrome
USA
6.7L Cummins
I have to say that my single zone ATC bezel from M2Mods is worth every penny in form and function and the shipping was really quick too. @Mpgrimm2 and @DeereGuy are absolutely wonderful to work with!!!
The knowledge and help here on the forum is just as important as any part you can purchase.
Yeah, I’m not knocking their work by any means, just can’t afford that at the current moment. But if I get the dual zone now. I can get a single zone later and send both and not have any downtime
Ramit2016
Chesapeake, VA
That was also my approach to it. Wanted to see if I would actually use the auto feature enough to justify it. You can still activate it with the single zone bezel, but just on the 8.4. After I decided I did use it more than I thought I reached out to Grimm. He was about a month out on those and I would need to send him both my single and the dual zone module. Drive my truck every day and that wasn't and option.
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
There is a possibility at some times that @Mpgrimm2 has competed single zone ATC units available for sale. That would eliminate any "down time" associated with shipping and not having a bezel.
Ramit2016
Chesapeake, VA
The last time him and talked he had mentioned he was trying to pick up some extras just for this. So absolutely possible that he has some ready to go now.
Ghost_RAM
VA
Since I just finished up with my last upgrade, this might be my next project! Time to start taking notes and compiling parts...
Cillys
Virginia
I must've gotten lucky. I bought my bezel off eBay ... Mpgrimm2 hooked me up with the harness and everything [emoji1303]else I still be rolling around with a RA1 radio [emoji85]
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
I managed to get my hands on 4 Dual zone bezels that I can pre- modify the control boards in advance so I can do a 24hr turnaround if someone sends me their MTC bezel & ship back via 2 day priority. Requires scheduling to minimize downtime.
I also found one MTC bezel so I can build one complete Single Zone ATC Bezel, but yes, it's a bit more if you figure in the cost of 2 bezels plus the board work.
M² Mods.
bhiii
#justsaynotochrome
USA
6.7L Cummins
does anyone know the part # for the factory screws to mount the sensor?
WTM75
Upstate NY
3.6 Pentastar
I was finally able to install the ATC board with the Off/Auto button in the center. I actually did the ATC conversation with @Mpgrimm2 harnness, back in September, but I was using the regular single zone bezel. Now that the holidays were over and I had a little spare money, I had Mpgrimm2 from M2mods modify the Dual Zone control board to work like a single Zone ATC bezel. As always, a great mod!!
mjf6175
NJ
cummins
NICE!.......did the exact same thing a couple of months ago. The ATC bezel looks and works exactly like OEM factory, excellent work by Mpgrimm2
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
  • Oh my goodness, took a ride to Vegas today and was thinking the same thing. I love my M2Mods products, single zone ATC conversion bezel and multiple harnesses for the 3.0 to 8.4 upgrade, ATC / humidity sensors, rear camera re-route and mirror microphone addition, overhead console w/Home Link. I started out with an ambient temperature of 38 degrees by Flagstaff and by the time I hit Vegas it was 78. Just hit that Auto button and VR button, say the temperature you want and never think about it again.
Thanks @Mpgrimm2 and @DeereGuy you guys ROCK!!!!!!!!!!!!!!
Edit: oh ****, I almost forgot my Deereguy bypass harness, lol
sdwalter
Wisconsin
I finally installed the temp sensor harness and added the humidity sensor. Was able to enable the ATC with the AlphaOBD tool. Everything works great. While I was modifying, I added the rain sensor and the smartbeam mirror. Now I have ATC, auto high beams headlights, and rain sensing wipers. I love it all.
In order to do all of that, I ended up installing a new oem harness to the mirror. I have the m2mods humidity sensor harness left over. I never installed it, as I didn't need it once I put in the new mirror harness. If anyone is interested in the humidity sensor harness, send me a pm and we can work something out.
Kleinja
Sycamore, IL
2015 Ram Rebel
Super happy with this mod! It's only been 1 day but I already know I'm going to love it. Got the temp and humidity sensors mounted and the harnesses ran yesterday and it was a breeze to do. Probably took a couple hours but I was taking my time, and also tinkering with a couple other things in between working on this. Only issue is I bought the cover for the humidity sensor and it didn't have the back plate (or that's also a separate purchase and I didn't realize it) but I'm just going to design and 3D print a cover for it and call it good. Just so the wire plug isn't showing and it's a little cleaner. AlfaOBD setup was a breeze and it was working great. Drove 2 hours afterwards and I was at a comfy 71° the entire way. Thanks to M2 Mods for the awesome wiring harnesses and the guides to make the install super easy!
2014EcoDiesel
Jacksonville, FL
Ecodiesel
Another satisfied customer. Thanks Mpgrimm2.
I didn't have the instructions handy and went right too ATC Single. It didn't work. So.... then i read the instructions, changed to ATC dual, waited a day, then back to ATC single. Works great!
2014Ecodiesel
FlatbedHemi
Maybe I am blind, but I cannot seem to find the instructions on where to find the options for ATC in AplphaOBD. Can someone please help me?
FlatbedHemi
Yeah, I read through all that, but still couldn’t find it. Ended up calling Mike Grimm and he was able to walk me through it. Problem was, the options that everyone was saying look for was not how my version had them listed. He had to hook up to his truck and walk me through it. Great guy and a HUGE help. Another satisfied customer of M2mods.
Eng50
Richmond, Va
Cummins 6.6l
Hands down Mike is a great guy and smart as hell..he and his buddy's make awesome products and interfacing parts that make our trucks a pleasure to be in...
Smart Beam Mirror
ATC
Radio info
The wiring these guys make are second to none better than factory in some cases and the support is just not seen these days like Mike gives..
Thanks again for everything, you made my world and easier place to live in!!
Bill
Sent from my ONEPLUS A6013 using Tapatalk
Orca
