how to fit 20x10 with 33x12.50 tires
vinc
Hey. I am going to level my 2016 Ram 1500 Big Horn. Im adding the 2.5" front level from rough country. I wanted to know if i can fit fuel 20x10 wheels with a -18 offset and 33x12.50 attire trail blade mt tires WITHOUT rub. will it work?
2014greatwhite
Western mass
I had the bilsteins set at 2.8 on my 2014 before I went with a 4" lift. I ran 20x10 -24 moto metal wheels and 35x12.5x20 atturo trail blade xt tires and only rubbed at full lock on the drivers side. There is a little bump on the inner fender well that barely touched. So with the set up you want to run I don't think there would be any rub.
quietpeen
2021 TRX
Hellcat
With the level you are putting on you can run that setup with no rubbing
Fanta1500
Albany NY
If you wanna get a lot of info on level kits and tire wheels set ups, search Brandonjanson on the forum, he has a huge post about basically all the info you will need on leveling and wheel and tires. Even if you don't need to know it's still a great read imo
