Can you get different LEDs and hook up a blue color one or red?
Bought the kit from Allmoparparts with the bezels and while it is exactly what I wanted to purchase, I didnt take into consideration the color. For those who might be interested in buying this it is indeed a warm white color of about 3000K, so if you have LEDs in your interior that are a cooler spectrum, say 6000k it kinda clashes...Also if you look up the phrase "**** on a boar hog" you will find in the description a picture of the foam tape used to attach the led module..took all of 4 hrs for it to fall off. Took it off and used 3m siding tape and it fell off as well after a day. One might think of a more sturdy mount for it. I am going utilize a threaded bolt led and a piece of plexiglass I think to stiffen up the carpet piece mount under the glove box.
the bezels wouldnt snap closed with the light assembly
You have to trim a little more carpet from the sides. I had the same problem at first. If you trim just a little more though they will snap in and hold it. (the sides not ends if that makes sense.)
Any p/n on these?Nice write up.
Check this out. Under $5
from a 99-02 Jeep Grand Cherokee. Check this out.
Same size indention on a 14 ram as the 02 grand cherokee light. Snagged from pnp
Harness location
Poke hole through carpet with Philips screw driver and slide light socket through. Makes for very snug fit and no need for tape or screw.
Now you can add any color light you want. There's a incandescent in there now for an example. Flush and "mopar" factory
Driver side. Can use somethin else if you don't want ziptie. Total install time maybe 10 mins.
White led bulb
found the p/n but they are $18.50-$22.50 each plus shipping, where did you find em for under $5?
