How To Install OEM footwell lighting
k1ng87
Can you get different LEDs and hook up a blue color one or red?
EagleChief
Oklahoma
2014 Big Horn
Good question. I wanted to put amber bulbs in my floor lighting, but from what I'm reading, there is only 1 option. :(
The Crow 1994
Nebraska
Hemi 5.7L w/8 Speed Trans.
Thanks for the detailed write up! The photos are a HUGE plus. What trim models have these lights already installed from the factory? I have a 2013 Big Horn and would like to do this mod.
SATXCTD
OEM footwell lighting installation
Nice write up.
Check this out. Under $5
from a 99-02 Jeep Grand Cherokee. Check this out.
Same size indention on a 14 ram as the 02 grand cherokee light. Snagged from pnp
Harness location
Poke hole through carpet with Philips screw driver and slide light socket through. Makes for very snug fit and no need for tape or screw.
Now you can add any color light you want. There's a incandescent in there now for an example. Flush and "mopar" factory
Driver side. Can use somethin else if you don't want ziptie. Total install time maybe 10 mins.
White led bulb
Samsonlabs
2014 Express Black
Bought the kit from Allmoparparts with the bezels and while it is exactly what I wanted to purchase, I didnt take into consideration the color. For those who might be interested in buying this it is indeed a warm white color of about 3000K, so if you have LEDs in your interior that are a cooler spectrum, say 6000k it kinda clashes...Also if you look up the phrase "**** on a boar hog" you will find in the description a picture of the foam tape used to attach the led module..took all of 4 hrs for it to fall off. Took it off and used 3m siding tape and it fell off as well after a day. One might think of a more sturdy mount for it. I am going utilize a threaded bolt led and a piece of plexiglass I think to stiffen up the carpet piece mount under the glove box.
loveracing1988
Clarkston, MI
Why did you use tape if you have the bezels? The bezel is what holds them on...
Samsonlabs
2014 Express Black
the bezels wouldnt snap closed with the light assembly
Samsonlabs
2014 Express Black
You have to trim a little more carpet from the sides. I had the same problem at first. If you trim just a little more though they will snap in and hold it. (the sides not ends if that makes sense.)
Yep did that...in fact I literally shaved the carpet down to the fiberboard (or whatever the stiff part is under the carpet. Still didnt click in..in fact I put it together without anything in between it and the bezel would just fall off. I think it had to do wtih the fact that the bezel arms were smashed flat when I got them. They didnt break off but they were really flimsy. Really doesnt matter though...as I said with the cool blue map lights and dome that warm yellow in the floor clashes really bad. Ill have some cool blue ones (6000k) to put in today so it will all match. I just hate to cut my harness.
CMil527
Old Bridge, NJ
2021 RAM 1500 LARAMIE-CC
Nice write up.
Harness location
White led bulb
Any p/n on these?
CMil527
Old Bridge, NJ
found the p/n but they are $18.50-$22.50 each plus shipping, where did you find em for under $5?
SATXCTD
At the parts pull place. Pick n pull as its called here.
Indaram
North Carolina
Hemi 5.7 Etorque
Just got a set of those round lamp sockets from the jeep for 10 bucks. Like this option as I can use the same 194 LED's I used in my map lights to keep the same light color. If anyone else is looking, the part number for those lamp sockets is 56042559AA
Indaram
North Carolina
Hemi 5.7 Etorque
And here they are installed with LED's :) Used zip ties for the driver side and a plastic push tab for the passenger side.
DRIVER SIDE
uc
PASSENGER SIDE
uc
CuylerTech
NH
2015 Big Horn Mega Cab 4x4
6.7L
I bought a set of red LED's from radio shack and just used a Volt meter to figure out which pin on the stock harness was +/- and just pushed the wires into the holes and heat shrinked them. Think total cost was around $5.
R.L.K.
Bristol , Tn.
Great initial write up ! I did mine exactly like ( MPG LOL )
Jared4.7
Olathe, KS
2017 Bighorn CC
Nice little mod for the cost. Stupid easy to install and gives off a good amount of light. Can't go wrong for 55 bucks.
-JT
moates49
