How to tell if rack and pinion is on its way out?
Luxuryram10
Aurora ohio
2010 1500 bighorn 4x4 just trying to get some ideas on how I can tell if it's going out or not. Put new rims and tires on and now it has a terrible shim in the front end. Yes tires are not balanced I know that will be some of the issue but I've always ran my tires that were 33" or bigger without balancing and have never had it shim as bad as it does. And it's not all the time. Going around curves it goes away to the right. If I go around a curve to the left. Gets worse. Any ideas on where to start? I've lifted the front end everything seems tight no slop in outer tie rods but I feel some in the wheel as it shins. You can almost hear it knocking. 0e313014380edda3a6311046b09a6636.jpg
DannyMK2
Long Island, NY
2015 Power Wagon
you should start by getting the tires balanced and having the alignment checked.
L
Luxuryram10
Aurora ohio
No need to balance the tires. They will never get them perfectly balanced. So that's is not the issue. Rides the exact same way with my stock set of rims and tires.
Freed127
Tamaqua PA
I call BS on the balancing. Im on my 3rd set of 35" toyos and my shop has never had an issue balancing em
L
Luxuryram10
Aurora ohio
I've never balanced anything over a 33 that is a mud terrain to soft and wear funny so not bs.
jljbtm
I've always balanced, sometime not easy but it makes a difference
Sent from my SM-N910V using Tapatalk
huntergreen
Marine Corps Navy Badge
Can't help, but your truck looks awesome!
L
Luxuryram10
Aurora ohio
Hah thanks man. Yeah I'm kinda stumped. The fact that it has this shim even with stock tires that are perfect. Just boggles my mind. Alignment shop even said the whole front end is tight. So im not sure what to do or where to start.
CVX20
Ont,Ca.
2019 Classic Express
They will balance the same as any tire,they just don't stay balanced as long.You want a permanent balance you use balance beads.
