I have a rather odd question
Budakane
Northern VA
345ci Hemi
Ok gang.....I have what alot of you might cal a dumb question, however I am curious. Being in the military, with a family money is tight. So my question is if I put 4:56s on the rear what would happen if i left the fronts stock?
S2kiHemi
Houston TX
You could only be in 2wd. If you tried to switch to 4wd then you would have some major damage.
rambob
LA/MS
318 5.2l
if you never put it into 4wd, nothing will happen.
if you do, bad, terrible things. wheels frantically hopping resulting in broken stuff, hopefully a ujoint before something in the axle or tcase
quietpeen
2021 TRX
Hellcat
what they said. I would be afraid throwing it in 4x4 by habit...but then it would be too late
MADDOG
Living in a Firepit
Good suggestions ^^^^
DON'T put in in 4WD or, better yet, remove that front driveshaft.
Budakane
Budakane
Northern VA
345ci Hemi
Thanx guys, I think will do front/rear....I want to run my 4wd
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Also make sure you keep the tires the same size, ya cant do like the 2wd guys do with the taller slicks in the back and the small front runners if you use 4x4.
