i have no speedo and odometer no lites
will
98 dodge ram
v10
98 ram v10 5 speed manual trans have no speedo and odometer have changed the sensor on top of rear axle no fix does not have the abs lite on any ideas thanks . gene on the header of this post it says no lites i mean the abs or brake lites are not on . just the speedo and the odometer is not working..
HolyRamBatman
Deep in the Heart of Texas
Welcome to RF.
Check wires and connections for corrosion or broken spots. There are a few things that could cause this problem you are having.
Have you disconnected the battery to reset the PCM?
dbdbasd
