redram2007
- Joined
- Sep 29, 2012
- Posts
- 1,092
- Reaction score
- 60
- Location
- Colorado Springs (Ft Carson)
- Ram Year
- 2007
- Engine
- 4.7
Every since I installed my 08 intake manifold, airram tb adapters, f&b 72mm tb, and my custom tunes my idle has been kinda wacky. After the truck has been running and warned up it will sometimes surge when I put it in park or neutral. It also will not idle up on cold startup like it used to, instead it starts out around 650-700 rpm and stays there. I have replaced the IAC valve, TPS sensor, checked for vacuum leaks, rechecked torque of intake manifold and tb mounting bolts, and returned the pcm back to stock. Anyone have any suggestions as to what my next step should be? These parts have been installed for about a year now and I just can't figure it out?
