In search of better brakes.
goodtodoo
1996 indy pace truck
So I have a 96 short bed 2wd reg cab, I would like stronger brakes. I have heard that the 2001 trucks came with 2 piston front calipers, my truck has single piston calipers. Also heard that the 2001 trucks had rear disc brakes, my truck drum brakes. Any truth to this. Or are there aftermarket kits available?
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
Most Gen 2 trucks 01s included have rear drum brakes, but a few have 4 wheel disk (I think its only the 2500/3500 though, or maybe just the dualies?).
However the 01s do have 2 piston calipers. You can get slightly better braking with the 01 front calipers, but don't bother trying to swap parts on the drums, its just too much hassle for very little gain.
A lot of performance is going to come from the type of brake pads. If you want straight performance, semi-metallic is a must. Sure organic is low dust and cheap, but they cant take any heat before losing stopping power. Ceramic pads are nice and quiet, produce little dust and are easy on your rotors, but they cant take heat either. Semi-metalic pads will eat away at your rotors faster than any other type of pad, but you can get formulations for light city driving through heavy duty towing use.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
If you had a 4x4 I'd suggest 2500LD brakes. But, being 2WD it makes it a bit harder. If you WANT to go through the work, go ahead and get the knuckles and what not for a 2000-2001 Ram 4x2. It SHOULD work, but you might run into issues with ball joint fitment.
Mohpar
Magnum 5.9
dodge dude had a good suggestion, but if you do decide to get pads check out hawk performance brake pads.
Bleed the lines, change the fluid, look into rotors as well. Drums aren't all that bad and since your braking is done up front, give them the most attention.
reyzapien88
