Inez 4/6 review
mighty noid
Culver City
Hydro Blue 2018 4x2 Sport Crew Cab
Well I am done for now. It does need to get an alignment though... but the ride is not rough at all. Doesn't hit hard or bounce. Great stock ride with a much lower stance.
I will give you my feed back about the kit next week. Here is a before and after look. I will get better pics after the alignment next week. The install is not an easy one at all. Thank goodness I have 2 awesome friends that know there ****!!!
There's been a few guys ***** about bump steer with Inez's kit.You might want your alignment guy to put some toe-in on your alignment to help compensate for the bump steer.[/QUOTE]
mighty noid
Culver City
[/QUOTE]
Thanks for the tip. I will.
mighty noid
Culver City
Alignment is all done... that wasn't cheap at all.
Tip... go to a shop that specializes in aligning road course/race cars... normal places won't touch it otherwise.
now it rides great and looks GREAT!
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
I read through alot ot this a few times. So did someone find a qa1 that fit or not? What other shocks are you guys using instead?
Better late than never, but I'm running Viking double adjustable shocks with my Inez 4/6 kit.
Mino
Ft Lauderdale
Thank u
I am from broward county
I SEE you are from kendall , i been reading all the post , don’t think I am a stalker lol
Quicksilver337
South FL
2016 Ram R/T
Thank u
lol that's cool.. yeah I've had the Inez 4/6 kit for about a year now. Installed it myself... I got KYB gas shocks for the rear, haven't installed it yet. Those Viking shocks look awesome but pricey.
DARKNHT
Georgetown, IL
What Viking # are you running, I want to check the specs. My TS709's topp'd out on the passenger side, and came apart. So I am curious on the Compressed/Extended lengths.
raginglaramie
Edmonton,AB
Update
So I finally got around to doing the front bump stops. Truck rides a lot better I didn't realise how often I was hitting the factory ones. But now i rub the top of the inner fender liner on large bumps and fast turns.
In the rear i cut the cups out and dropped it All the way down to see where the shocks bottom out. The beilstiens bottom out with 1 inch between the axle and chassis. I ordered a set of one inch bump stops with the to bolt hole tabs because there's no way to use the bump stop that has the stud because the factory bracket is boxed off. I'm gonna put a 1\4 inch plate under the new bump stop so I don't bottom out the beilstiens especially since I cut another coil to get the full 6 inches in the back and there is roughly about 1 1\2 inch of travel back there.
Anyways just really wanted to let people know that you can run the beilstiens shocks in the back and get full travel out of it with a 1-1 1\2 inch bump stop in the rear. And the springs are still long enough not to fall out at full drupe.
Do you remember what part numbers the bump stops were?
T
Twistedshadows
Did it so long ago I don't remember. But just a warning for every one I ate through my liners and In to my battery tray and a wiring harness laying the top of the passenger liner (caught the harness before it ate any wires). The tray is just some plastic and the harness can be *******. I've now completely removed my liners and also hammered some metal above them out of the way. If your gonna remove them there is a huge wiring harness hiding behind the driver side liner your gonna what to move to the inside of the frame and heat wrap.
Lowrider357
