Infinity speaker replacement issues
Mando87
Dallas
Greetings everyone, I have a 2004 Dodge Ram 5.7 hemi with infinity audio I bought some new Infiniti speakers to replace my old ones and when I connect them I have no sound nor from the old ones any help is appreciated thank you
Fast69Mopar
With the truck being 21 years old as well as the original Infinity speakers and amplifier I would suspect that the amplifier has failed or it is not receiving an audio signal from the radio.
Get a printout for the radio and amplifier connectors and make sure the amplifier is receiving B+ battery voltage and a good ground.
To test the speaker wiring from the radio and amplifier connectors you can use a 9V battery to power the circuit to the speaker. You will hear a little pop or a crack when you power the circuit because it will flex the voice coil. This is where I'd start my diag.
joshhhh
