Installing Zone 6"/5" Kit
Revo
Canada
5.7L
Looking to see if any of you guys who have self-installed your kits on your trucks ran into any issues during the install? Or maybe were told something by the shop/person who installed yours? I'm planning on doing mine with my cousin next weekend (GM mechanic) and just wanted to see how you guys found it.
I guess this goes for both the 4" and 6" kits, as they seem to be pretty similar.
Dantheman
South Carolina
The hardest part for me was cutting the cross member, which wasn't even that bad. The only issue I had was putting the new front crossmember in. I tried putting one side in then bringing the other side up but for some reason it wouldn't fit. The only way I could get it was to get both tabs in at the same time.
homebrew
Cummins
Just did mine about a month ago. Hardest part for me was the rear control arm brackets, they didn't match up with the existing holes like they should have so I had to get creative with a few. Called tech support a few times. Did it by myself, an extra hand would have sped it up but I wanted to do it myself
robbob
Drilling the holes in the rearend upper control arm mount. The holes on the outside bottom of the mount you need either a short bit or a right angle drill.
Revo
Revo
Canada
5.7L
When did you need to cut the crossmember?
Revo
Revo
Canada
5.7L
How long did it take you to do it entirely on your own?
Dantheman
South Carolina
I'm guessing you haven't read the instructions. On page 10 of the zone instructions is shows were you have to cut the rear cross member to allow the diff to drop down correctly.
Dantheman
South Carolina
Sorry, they call it "The driver’s side rear lower control arm pocket"
homebrew
Cummins
Two days probably 15 hours between the two
Revo
Revo
Canada
5.7L
For the sake of being cautious, I am cutting straight through this red line?
I'm just confused as to why they have 3 lines drawn on the picture.
Dantheman
South Carolina
Not quite, the far left line is the one you need to cut, with the bold dashes. I don't know why they have the other 2 lines. I see that you live in Canada, you may want to pick up something a little stronger than average spray paint to coat the bare metal so you don't have to worry about rust.
Revo
Revo
Canada
5.7L
Ah, I understand now. Thanks.
I was thinking of priming and then using high heat spray paint and topping it off with a quick coat of spray bed liner. (Just to be safe)
Dantheman
South Carolina
^^^I commented on another thread about that too. I didn't trim mine down and everything worked out fine, maybe it was just me though. Let me know how the bed liner works, I want to repaint mine.
Revo
Revo
Canada
5.7L
Will do. I sprayed my hitch with it and it's very durable.
Do any of you happen to know if the picture displaying the parts is accurate to the 6" kit? I can't seem to find the following 3 pieces.
EDIT: Nevermind. I guess I'm missing some parts. For some reason I had remembered the 4"/6" kits having the same picture.
Dantheman
South Carolina
Oh and two more quick things, the original front diff brackets are a pita to get out, I found that an open ended offset wrench worked the best. The other is that I cut a wrench in half to get to the rear upper shock mounts easier.
homebrew
Cummins
The black thing is the bump stop extension hard to see what the other things are
robbob
Go to the BDS website and print out their instructions as well, same instructions with a few different pics. They use a longer brake line in the front zone uses a relocation bracket.
Kdog57
