HEMIMANN
- Dec 7, 2020
- 9,693
- 25,394
- Location
- Minneapolis, MN
- 2017 2500 Laramie Crew Cab
- 6.4L HEMI
Today we scrubbed momma's GDI Turbo Engine guts with CRC Intake Valve and Cleaner @ 32,250 miles. Mazda is one of few turbo GDI engines that built in some kind of coalescing breather into the PCV routing. It's just a baffle box, but better than nothing at all like many builders do. This info from reading up on their engines.
However, it sure doesn't seem like they have a default limp mode! The cleaner spray is highly concentrated PEA and is not to be sprayed onto the MAP / MAF sensor, so it has to spray downstream by disconnecting the air intake tube. Man, that engine bucked, sputtered, and backfired like crazy, but we got through the ordeal. Seems to run fine after re-hooking the air intake up. Then we changed engine oil.
I don't have a borescope, so WTF knows how much good it did? A couple hours and a $25 can for home-made "Induction Service", done per Hoyle.
"Ees Clean!"
*pop*
"Ees Clean!"
*pop*
