intake?
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
And that is simply Badass!
Trupiano
Registered User
6.7L CTD
I LOVE my Vararam Hemi Under Glass intake :)
If you have never seen a Vararam, here are some of my pics
Honestly if I wasn't concerned about flooding my truck with water with this ginormous hood and all the rain and flooding we get here in arkansas, I definately would have went with a vararam! Those seem so badass! But there's no way it would have worked for my truck.
Good pictures though!
bigtigga84
dela....where?
infamous "*******" intake. i used 4"pvc. one street 90 from the tb two pieces of 24" pipe, 60 degree angle and a 4" adapter down to 3" spectre blue filter. it was loud as ****(no pun intended) till i started screwin with the exhaust. cb extreme pretty much drowns........ everything out lol. specially right before the tire
Redtruck-VA
Virginia
Over on DT there is a long thread about Vararam and a lot of the results from their technical test proving how good it is over other intakes. But basically the engine has to suck air through whatever you choose to run. The Vararam is piped to some high pressure points which increase inlet pressure so it has an advantage over the average setup.
RAMpage
Kentucky
custom 5.7/6.1 hemi hybrid
I have the vararam setup on my truck and love it. i can feel a good difference around 35mph. plus it takes care of whats uncovered when the hemi hats removed. actually trying to find some orange intake tubes to match the air cleaner cover but havent had any luck. as far as intakes go your really getting what you pay for compared to a k&n and other comparable cai's plus it looks so damn good. I have had people pull into gas stations just to talk to me about it when checkin the oil. for 399.00 i think its very worth it.
RAMpage
Kentucky
oh and trup do you think the vararam would fit under that sick ass hood youve got, ive been thinkin seriously about snaggin one this spring
Mike42488
Mike42488
Long Island, NY
so i got the cai from ebay. i installed. heres what i got lol.\
doesnt really look right. its throwin my gas mileage off, any ideas why its doing that. its kinda jerry rigged in there, i may take big t's idea and hit up homedepot tomorrow. any ideas on hot to fix this monstrocity???? thanks fellas
ramhunter9
P-Star Jeep Wrangler
I built mine out of poop pipe and slapped a K&N on it .... works for me and it was fun to build
OklaHemi
new age hemi
reset your pcm. see if that helps. remove the neg battery cable for about 10 min on the 08 i think, im not sure
bigtigga84
dela....where?
you can use what you got so you didn't waste your money and just get a straight piece and a street 90 elbow. should fit together with what you have. gonna need a grommet and a half inch hole saw i think to put the IAT sensor in the poop pipe
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
close, its a BFI - same design, same ponzi scheme ********. Good luck getting one, your best bet would be to look for a used one on the forums.......the new ones (composite material vs the metal shown above) went through the same BS to get them to customers (ie, you pay now.......get it it in 3-6 months).
Mike42488
Mike42488
Long Island, NY
i took off both pos and neg for however long it took me to install prob bout 20 min. didnt work. then last night i left both pos and neg off over night bout 6 i'll see by the end of the day if that worked....
moparman33
Cordova, TN
2004 QCSB 4X4
4.7L magnum
just like dan a.k.a. the assassin said, you wont see big gains from an intake. add a intake and exhaust you'll be able to tell a difference, but still will not be anything huge
Redtruck-VA
Virginia
Nicely done....
