FaceDeAce
Well folks it is 2026 and that old 2004 Ram 1500 with 5.7 is still going. Now still zooming around scaring women and children at 340K on the odo.
For the past while it has been getting a bit sluggish at low rpms on inclines. I suspect either it is getting tired or that original EGR valve is failing. Unplugged the problem goes away. Plugged it gets boggy below half throttle on slight hills.
So I figure the EGR is the primary culprit. There are no codes for it in the obd.
What I would like to do is just put a blinding plate between the valve and the port on the head. Leave the valve in place and the electrical plugged. In this way there will be no exhaust going back to the intake, and no tuning will be necessary because the valve is still physically there and electrics plugged in so the pcm still sees it.
My question is: has this method been done by anyone here? What are pros / cons of ditching the recirc?
PS - I do not care nor am I bound to any emissions related regs in my area.
