is my tread depth OK for snow?
tobyd
Longmont, CO
3.0L V6 Diesel
Hi,
This is my first truck, previously I've had SUVs. I bought the truck at the end of last winter and had it in one or two light snows, and it was fine for what I was expecting.
The previous owner said he figured the tires would need to be replaced before this coming winter.
They have between 9/32 and 10/32 of tread, which for a car or light SUV would be ample, but how's that on a truck?
It's running Falken Wildpeak AT3W at 295/60R20.
Thanks,
Toby.
chopperman1
2018 Rebel
5.7L HEMI
How far are they from the wear markers? That will tell you remaining tread depth. It also is very different between LT tires and passenger tires.
T
tobyd
Longmont, CO
3.0L V6 Diesel
The wear bars are not obvious, but seem to be at about 2/32. So I'm waaay above those, but if I took it down to 2/32 they'd look pretty much bald.
rule18
Admin
NY
2017 Rebel
Hi,
Thanks,
Toby.
If you've got 9/32 right now, that's roughly half the tread of that tire when new. Seems like you'd be pretty good for the winter.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
And you have highly-rated tires as well. You're good!
T
tobyd
Longmont, CO
3.0L V6 Diesel
Thanks all for the replies, it sounds like I'm good to go.
BWL
Embrace the skeptisism
BC Canada
If they're snowflake rated there's 2 different wear bars. 1 for replacement time and 1 for no longer winter rated. That will tell you if you're good or not.
