Is this normal?
HEMIsphere05
MO
6.7L cummins
I noticed last night when I parked and had the wheels turned hard left. That when i was walking back to the truck this linkage looked to be dropping pretty low. This doesnt seem right.
Is this normal it just dangles?
The wheels are straight in these pictures but it still seems to have a lot of slack. I would assume this is supposed to be mounted to the frame in some fashion. I just bought the truck last week 2016 big horn 1500 30k miles.
HEMIsphere05
HEMIsphere05
MO
6.7L cummins
This is on the drivers side
HEMIsphere05
HEMIsphere05
MO
6.7L cummins
Parking brake cable I would say.
should not be hanging that low.
Thanks I will schedule an appointment to get it taken care of. I didn't think it should be that low as it could get caught on stuff
MarshRam
2014 SLT 4x4, 2012 ST
You do not appear to be missing any mounts, but it does look a little saggy. Mine is as straight as a board. I'm thinking it may need to be tightened, but not sure if you would tighten it at the area in your first pic. Never had to mess with it. I am sure someone here can let you know where to tighten it at.
HEMIsphere05
HEMIsphere05
MO
6.7L cummins
Found a few other threads could be corrosion in the rear parking brake mechanism that doesnt allow a lever to return to the normal position which then has slack in the line.
BadHabit57
Missouri
I've seen this on my friends truck and it's what the guy above said.
NCRaineman
NC
2019 1500 Classic
Parking brake cable, have that checked and adjusted ASAP for safety.
14RAM1500BG
maryland
I would not adjust until the issue is found. My drivers side parking brake lever was frozen from rust and not releasing, once found and fixed it didn`t need adjustment.
HEMIsphere05
HEMIsphere05
MO
6.7L cummins
I'm not going to adjust it myself. I hit it with a lot of wd40 and it seems to be a little better. Going to let dealer look it
David Janes
Iowa
3.0 Diesel
I just found the same issue with my truck. What ended up being the solution when you took it in?
Frontbutz
Ohio
My 2015 has been doing this too, I have to bang it back with a hammer at the wheels. Does anyone have a video of replacing the corroded levers? I see dorman has the levers and rubber boots, but not sure how they attach to the drum brake hardware. The dorman p/n is 924544. If the OEM levers can come out easily, I might wire wheel them and paint and lube and reinstall or just get the dormans.
shaunnz
