Jack's Full Dynamat Build
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
Goal: full dynamat, dynaliner, dynapad and hoodliner build over next few weeks
I will post pics and add comments along the way. Any questions, just ask!
Dynamat and Dynapad full interior BEFORE roof - used 71 sq ft for each.
S0CAL
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
1/2 dynaliner on back wall, rear bench and C pillars. Tight fit. Now I can't do the rear seat fold mod. Oh well!
Ajwalk2008
Springfield, il
I'm wondering how much of a difference this is going to make
TomT
SoCal/OC
I had the same thing done to one of my previous Rams and it made a huge difference. My current install only has the doors and rear wall deadened. At some point in the future I will have the floor and roof done as well.
S0CAL
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
This **** better be pin-dropping epic. The cost and sweat equity is rough.
I put the driver seat in after dropping in the dynaliner and re-inserting the rear seat, took it for a spin. Not a significant change yet, but the console and passenger seat are out, as is the carpet. I think once the doors are done, that should be noticeable. I will let you know more next weekend.
Beer:30 :favorites13:
Jwithing
STL
Sweet. Keep us posted. My box comes tomorrow for my two JL 10w6's and I thought about doing this as well. Any tips/tricks for the install?
S0CAL
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
If you are doing dynamat anyway, go the distance and put dynaliner on as well. It will keep your truck quieter. Some believe a minimum of 30% of Dynamat is needed. I opted for 100% for added resonance elimination, insulation and a surface for the dynaliner to adhere to.plus I have OCD, lol.
The dynamat is easy to cut with a razor knife. I also find myself using the handle and not the actual roller of the tool. Don't waste time using dynamat tape. I see only cosmetic value for it. Dynaliner covers it all anyway.
I used rubbing alcohol on all surfaces and was astonished how clean the truck was when I pulled the carpet.
Have an impact wrench or a breaker bar at the ready. 15 and 18 mm sockets. Also have a panel popper tool for the scuff plates and B and C pillar panels.
I opted to not wear gloves and paid the price, razorblade thru the thumb, but not related to the dynamat cutting lol.
Beer and music are a must. It is tedious work. You will not regret the effort and you will learn a lot about your truck too. Have fun!
WilliamS
Tampa FL
Im curious to see how you will do the roof. How is it held up there, I hope to god its not Velcro and Tape like the 300's.. Once you pull it off it makes noise for the rest of its life.
S0CAL
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
You are so right. This is my fear too. The butyl in the dynamat is highly adhesive and I gotta think a perfectly clean surface and methodical application will ensure adhesion. I am going to try 1/4 in dynaliner but don't know how much clearance there is. I may have to go 1/8th. i am very OCD so I will be running through nitril gloves every few minutes. If this thing gets dirty I am gonna freak, lol.
adrianp89
Tampa Bay, FL
If your not using a roller I would suggest getting one ASAP. Otherwise looks good so far. I also wouldn't bother testing for a difference until everything is back together.
moregrip
please post pics of the roof and doors! And maybe some detail on the removal on what issues you ran into(or didn't) and maybe some of the less removed panels......I appreciate it! I'm not that far behind you, getting ready to do the same thing!!
S0CAL
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
Yeah I got the roller and it is ok for the flat surfaces, but i use the handle in all the angled areas and then use it over the entire surface to create grooves to REALLY make sure it is sticking. I don't every want this stuff coming off.
BTW, I stayed clear on putting Dynamat on the B and C pillars where it might drip onto the seatbelt at the bottom. Instead, I reached inside the outter-most wall and slapped a few pieces there. I did line the B and C pillar panels with 1/4 in Dynaliner. I first pulled up the carpet liner-like insulation that was there. (this is where I sliced open my thumb, pulling that **** off).
S0CAL
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
Deal. :favorites13:
autokraftgt
Hemi 6.1
looks like you're doing a thorough job. Well done. What made you decide on Kicker?
Jwithing
STL
You mention clearance is tight for the backseat and you won't be able to use spacers for the fold down backseat mod. Any idea what application would still allow for this clearance? Going w/ a fox acoustic box that requires the backseats to be lifted for clearance
S0CAL
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
If you went with 1/4 in dynaliner instead of the 1/2 in I used on the deck, I bet you'd be good to go on the rearseat mod.
Fixed!! I simply remove a 1/4 in circumference on the holes and the rear seat foldown mod works!
HEMI_Finn
U.S. ARMY Veteran
Army
N.E. Ohio
Hurricane 3.0 HO
I'm interested to see what kind of fuckery you have to go through with the headliner, do you have a sun roof?
I plan on doing my doors but really want to do the whole interior. Good luck and keep us posted!
