Jba header o2 sensor question
Kgibson1315
Mayfield, KY
I purchased the jba long tubes and it came with 2 o2 sensor extensions. Do I need to purchase 2 more extensions? Thanks
Cowdog
Santa Maria
I had too
More than likely you’re gonna throw a code if not let me know or how you fixed the problem
I built my own Y pipe (no cats) but put bungs same distance away as stock
DILLIGAF
Canadian Forces
Canada
They delete the O2 in the custom tune. So I just used what was in the kit as it just for show...lol...
RedSRT4Me
Scottsdale, Az
2015 CC Sport
No the extensions are for your after cat downstream O2 sensor locations. The upstream O2 sensor should install into the collector without issue.
Kgibson1315
Kgibson1315
Mayfield, KY
Does it matter where each o2 sensor is used or do all 4 function the same no matter where they are put?
Keep track of where they go,you'll also want the back ones plugged in,you can tie them up to the tranny so they're out of the way,but odds are even if you delete them in your tune,it'll still throw a code if they aren't physically plugged in.They don't need to be in the pipes,just plugged in
Kgibson1315
Kgibson1315
Mayfield, KY
Too late for that, all I know is 2 sensors have white plugs and 2 with black plugs. I did load the custom tune Hemifever sent, but not sure what all is deleted in the tune.
Kgibson1315
Kgibson1315
Mayfield, KY
After researching some more I installed all 4 o2 sensors and only plugged in the 2 upstream sensors. I believe the downstream sensors were removed anyway with my new tune.
Dan98
If o2 is deleted than there should be no need to plug in. You should not get codes either. Downstream sensor is the one that causes limp if unplugged and un deleted. The one down stream or after cat reads 02 on 4 sensor system 2 sensor system they read heat 02 and time. Cat or no cat wont code for smog just reading issue voltage temp or open circuit.
Sent from my SM-J260A using Tapatalk
Kgibson1315
Kgibson1315
Mayfield, KY
I just screwed the 2 downstream sensor in the y-pipe holes and left unplugged since I didnt have extensions anyway.
Saleen5150
