JBA UCAs
LoadedExpressRam
Gulfport, MS
So currently i have a set of front uca's from JBA but im running a front leveling kit which they suggest when using them. My question is would these work if i brought the front back to factory height and lowered the rear end. Some on the website say yes but JBA says no. Im having a hard understanding why they wouldnt. Appreciate the help.
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
My opinion based on a quick review of the website, they don't appear to have a ball joint that corrects for the lifted angles, so unless they are shorter or longer, (can't measure distance or arm length) I couldn't see why they would not work..
But I don't own a set. Have not used them, certainly never installed them, so my opinion is strictly that, an opinion.
crazykid1994
I would not. If they are designed for leveled applications it means the ball joint should be angle corrected and at stock height would throw off your alignment specs. You could always purchase the mevotech UCA fairly cheap and swap those and sell your jba UCA
gville35
