There is no way around a gear change it's gunna be 3k plus with there great idea to weld the front ring rear in and when I got my truck 2 years ago it would do the same thing when it was cold so I've had it reflashed 2 times before getting a tuner hoping it would help firm up the shift points. Maybe it's only a problem in colder temps but 2 of my friends trucks do the same thing unless you drive them aggressively and they still do it some and I can't see driving aggressively making the tranny last any longer? I live in the middle of no where and it's hilly country roads 35-55mph northern Maine roads so I'm almost always in 4th and that's the weakest gear. After dealing with it for 2.5 years I can see a lot more flaws with my truck with only 15000 miles compared to my dads chevy with 40000 miles and his is used for work and plowing and is far from being taken care of as well as mine. In all honesty I baby my truck a lot. With that said I'm selling my truck tomorrow and making the switch to chevy. Maybe if I had a 8 speed it would be different but mopar is seriously lacking in anything aftermarket
I'm glad you guys have had good luck with them but 3 outa the 5 rams in my town all have the same problem as mine. So I think your 200 out of 300k is off a but there chief but good try
Anecdotal evidence is and always has been a terrible way to back up a point because the variance of personal experiences is endless. For example I could counter your example with the dozens of ram trucks not having this problem in my parking lot. And then another poster can counter me by saying the complete opposite at his work. And so on.I'm glad you guys have had good luck with them but 3 outa the 5 rams in my town all have the same problem as mine. So I think your 200 out of 300k is off a but there chief but good try
I've started driving more in 3rd . Higher rpm but figure is easier on clutch packs from 3-4. Sounds better too.
The mileage is inconsequential as if you're light on the throttle 3rd gets ok mileage according to the dash compared to 4th. And it'll never drop a gear accidentally by steeping on it.
I use manual mode almost exclusively unless highway. But use manual mode for all downshifts.
All because I'm paranoid about it.
Come spring time I'll be at roughly 45000 kms...I'll. Flush tranny and add new filtration. Piece of mind.
(That's when it's most lowly to blow after spending time and money on it right?? Haha)
Please tell me how to drive it? Last time I checked these things are made to be driven and didn't come with a rule book on how to drive? I hardly ever go wot and usually drive normal. Not my fault ram is restarted and can't build a tranny to save there life not to mention there amazing shift pattern and not to mention 1st gear is way to high but hey let's stack 2nd and 3rd 150 rpm apart and make this 6 speed a 5 speed and while we're at it let's make the gear that you drive in the most the weakest (4th). And then there is 0 after market options. Never again will a buy a mopar product I'd much rather have a under powered gmc over a truck that will fall apart if you drive it slightly aggressive and has practically nothing aftermarket and everything aftermarket cost so much it's not even remotely worth it
A regear does not cost that much. I will tell you it makes a big difference. Your attitude is pretty much like the title of your thread right now. Giving you an idea of what you can do to enjoy what you have and not spend an insane amount or take a bath on a trade. I have an old 4th gen on here has a lot of miles and probably half while towing and yet mine works very well still. I attribute that to maintenance and regear. Take it or leave it.
actually, in the jersey area, that price isnt out of line for front and rear. , maybe 500.00 high. no idea what things cost in maine though.
