- Joined
- Mar 24, 2014
- Posts
- 2,918
- Reaction score
- 5,447
- Location
- South Jersey
- Ram Year
- 2010, 2014
- Engine
- 1500, 3500
LOL - now you got me thinking, I don't remember what size I bought. Have to run out to the truck and look tomorrow.
That's very similar to the screw jack that came with the 1985 Chevy C10 Silverado I used to own. I swapped it out with a 2 ton bottle jack. It struggled when lifting one of the front wheels but it worked for me for the 10 or so years I owned the truck.Thanks for the reply RamDiver. Here is a picture of the stock jack . It is a non hydraulic gear driven hand crank jack . It was inop when I got it. Yes , a high lift bottle jack might very well mount in the same exact spot
Thanks...
LOL, me too, but I'm sure it's an 8 or 12-ton.
Both sizes at CTC have a 17.32" maximum lift height and I tested it.
If I have to change the rear passenger side with a soft shoulder, I may not be able to lift at the pumpkin which AFAIK, would result in the smaller jack being next to useless for my Warlock.
Maybe, I missed the secret lift point at the back.
Have you not tested lifting your truck at both ends with the standby jack?
No, I haven't, I've actually only needed to use it a few times, when I rotated the tires on the 3500, (I've since gotten a floor jack), once on the camper when one of the china bombs exploded, and once on my 1500 when I got this. I'm sure if I didn't have it, I'd have needed it about 15 times.
The '70s D-series came with scissors jacks.Good morning Bob
I would trust one of the old-style jacks that clipped into the bumper if that's what you have but I forget what was typical back in '84. How about posting a pic?
The POS toys that manufacturers have been supplying in the past couple of decades are pathetic and a great example of the absolute minimum requirement that is provided.
Many of us carry high-lift bottle jacks because they're compact and don't require much real estate in a rubbermade box, on the ground or at the lift point on the truck.
Your project looks like it's coming along great, thanks for sharing your adventure.
That is what I thought, they will work, but you need level ground and a about 12 inch of 2x10 under the base.Thanks for the reply RamDiver. Here is a picture of the stock jack . It is a non hydraulic gear driven hand crank jack . It was inop when I got it. Yes , a high lift bottle jack might very well mount in the same exact spot
Thanks...
