Just got a 2017 Rebel with only 32k miles
RichieAprile
North America
5.7 Litre HEMI v8
Haven't done anything to it yet aside from replace battery. Air suspension was removed by the first owner. In the future I might try a lift and bigger tires. But for now it runs great and is a lot of fun to drive.
turkeybird56
Central Texas
WELCOME, nice looking ride.
1) Previous owner pulled air: Good, saves you the trouble later.,
2) The Rebels already have a factory lift, IIRC.
3) Rails already installed, good.
4) Back cover on bed, too.
ADDED: I would not change the truck with any bigger tires or a lift, changes the geometry of the parts,. lots of wear and tear. But your ride, your wallet, do what makes you happy. I would only lift and do bigger tires if you needed it work wise. ALL above IMHO.
RichieAprile
RichieAprile
North America
5.7 Litre HEMI v8
2) Front headlights look aftermarket also.
5) The Rebels already have a factory lift, IIRC.
Thank you, great points about the bigger tires and everything else. I was wondering about the headlights, I think I might want brighter ones.
turkeybird56
Central Texas
There are a lot of threads in this FORUM ref changing headlights. My 2019 is OEM LED, so I have neva had to play. MAKE sure you do your research on the lighting available, just skerry thoughts
southalum
