Just Got My Blackstone Analysis Back
Norwain
North Little Rock, Ar.
2016 Ram 1500
Oh, and I change my oil 1 time a year, whether it needs it or not. I’ve got 3500 miles on my truck, and it’s doing fine, and my wife says I drive like a maniac. She is not a psychiatrist.
OC455
OC455
Central NY
So there wasn’t 14k on the oil. There’s 14k on the truck? Basically 7k miles on each of your first 2 oil changes? I think you wrote the something wrong on your oil analysis slip they clearly think there was 14k on your oil. Now that you’re approaching 23k your minder will be telling you to change the oil for the 3 time correct?
No, I bought the truck and ran it to 7200 miles with the oil that it came off the lot with, 10% on the oil life indicator, changed the oil at 7200 miles. 1st oil change, went with Amsoil. The 2nd oil change occurred at 21400 with 15% oil life on the indicator. 14,200 miles on the Amsoil.
OC455
OC455
Central NY
Im not trying to be an ***, But whats with all the trying to get high mileage out of your oil when your truck costs $80k+ and your oil change is $100.bucks. I have mine changed every 5000 miles thats $2000 for every 100,000 miles. Not understanding the waste to pay for a test at 10,000 miles and run the oil for another 10,000 miles. Whats this test cost anyway...The price of a oil change...
The oil analysis cost is $30 ad $10 for the TBN result. Wasn't trying to get high mileage out of the oil. I wanted to see what the wear results are.
Alex_CO
Colorado
Hemi 6.4L
I guess it's pretty good with the Amsoil and Amsoil filter at over 14k miles for the oil change.View attachment 504013
This may be a dumb question, but for my 2016 2500 6.4L HD (80K miles, no mechanical or transmission issues) I can buy 7 quarts of Mobil One + a high mileage filter online for $45 and it takes 20 min to drain the oil and change the filter in my driveway. I go to approx 7k between oil changes. For $45 per full synthetic oil change, what is the point of stretching oil changes out to 15k+ miles in between...?
OC455
OC455
Central NY
I dunno....
See post #43....
farout75
Laurie, MO
5.7 L
Just my opinion, but 14,000 miles on one oil change is too risky for me. But with high Dollar Amsoil oil products you have to go that far to be able to use the products.
farout75
Laurie, MO
5.7 L
They said try 16k miles...not 18k. I'm going to keep it conservative and not push it too much. I did my oil change and added Lube Gard with the Amsoil to see. And my truck is over 22k miles now, approaching 23k miles.
Amsoil as far as I am concerned is a Pyramid kinda of set up. If your happy and you engine holds together try 20,000 miles. Maybe they will give you some reward. It all reminds me of "SLICK 50" from decades ago. This just is not the way I would ever go. Good luck.
OC455
OC455
Central NY
Your opinion is yours...I was posting what it shows with the wear results. Have a great day.
06 Dodge
Forest Grove, Oregon
6.7L CTD
Your post shows how much you don't know about synthetic oil or that some are capable of 20K OCI and still protect the engine, but to get those long OCI one should also use a high quality oil filter that can last that long...
Dusty
Rochester, New York
A while back someone asked me why I don't participant in the oil discussion threads. I also know a guy who kept hitting himself in the head with a hammer because it felt good when he stopped.
Regards,
Dusty
2019 Ram 1500 Billet Silver Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 3 June 2018. Now at 78888 miles
Dan Topp
Jefferson Wisconsin
Regards,
Dusty
I do it once in a while to feel better about buying new,and breaking in a new engine properly.image.jpg
And those peoples opinion on oil is irrelevant.
You do realize a 1Gal jug of RL in B******K nowhere Alberta is 90$ + Freight . and the RP Filters I need to get off Amazon.com and shipped up here.
But thanks for posting a US link for oil . :rolleyes: The funniest part of that is this
65.62 US is 90.01 Canadian :upyours:
Next time you're in Edmonton or Calgary stop by JB's and stock up on Redline and Royal Purple filters Ian,they're Amazon's Canuck supplier and it's cheaper to buy from them,then to go through Amazon.ca
blackbetty14
CT
Hemi 5.7 VVT/Etorque
Ill stick with 3k and let others destroy their engines.Especially when amsoil does the same torture tests.But thanks anyway.
Whats funny is that you think the frequency of the oil changes matters vs better oil and filters and extended changes. Quality oils will have better used oil ratings at 10k than the cheap stuff at 3k and thus the cheap stuff lubricates less.
Burla
2010 Hemi Reg Cab 4x4
TBN synthetic starts about 3tbn over conventional, and tbn is your oil change interval. Not only pays for itself with interval, has better cold properties and hot properties and doesnt have contaminants inside the oil. Despite all of this, there is no real proof synthetic makes your truck last longer, why, because our engines are a very forgiving application. Having said that, I'm not putting contaminants from crude oil in my sump when oils such as kirkland, walmart super tech, even havoline 6 qt box are so cheap. In some cases, those three are cheaper then conventional oil.
Dan Topp
Jefferson Wisconsin
You are funny too! I’ve used amsoil for at least 20 years and always the best filters.Cannot abide with all these priv torture tests when the same data has always been available. Start talking about break in procedures and heat cycles ect. and I’ll be a fanboy maybe.image.jpg
gofishn
Iowa
hemi 5.7L, 345 cu in
5K oil changes are the joke. ;) The only reason I do mine once a year is the -50 weather we get. If I lived somewhere with dryer climate or do way more driving Id give 20K a shot for sure. with an Oil test at 10K.
Ive seen my old man go 30k on his rig. And the UOA was still good... lol... Yeah I know the capacity's aren't even close but its still shows how long good oil can last.
Do you have ANY IDEA how hard it was , for me, to stretch oil changes out to 5K miles?
I STILL get freaked out by gong with the 5K intervals but I do it.
Of course, first truck I ever did that with had a failed lifter and ruined camshaft.
maybe I should go back to 3k Oil Changes and save this trucks cam
John Schmidt
Snowbird - USA
5.7L Hemi w/FLOWMASTER 50 SERIES DELTA FLOW
I've not gone past 3k on my 2020 - just can't get myself to do it. But I do sleep better knowing that the truck always has pretty new oil. 3k or 6 months, whichever comes first! (and don't laugh - but that's with Red Line.) Good luck sleeping :)
- John
