Just won’t move
Chadp0517
Houston tx
I have a 06 ram 1500 2wd with a 4.7 Today I was doing around 65 mph on the freeway and hit a good size bump in the road. There was a Big Bang and I lost any movement in drive or reverse. When put in drive from park there is a couple clicks and then it will engage very hard but will not drive. When u give it gas it acts like it wants to move but just don’t have any power behind it and it does the same when put in reverse. It is a 2we but it has a 7” lift if that’s makes any difference. Fluid level is good and it rolls like normal in neutral and when put in park it’s like normal
C
Chadp0517
Houston tx
Yes the shaft was spinning. Ended up being rear diff. Spider gears were shattered
