Knocking That doesn't speed up
GENCOUPE16
Tn
Just bought a 04 ram 5.7 that has some issues, fixed most things but got this tapping sound that doesn't speed up with rpm but is accompanied by a miss at the exact same time. I've tuned it up, and cleaned the throttle body and pcv...still there...gonna try and upload a video
jws123
nj
Run it without belt see if it goes away if not you need to pull the valve covers have a look could be a broken/breaking valve spring 3rd gens where notorious for that but could be alot of things dont drive it/run it alot until you find the issue.
G
GENCOUPE16
Tn
But wouldn't something like that speed up with rpm?
rzr6-4
nebraska
'09 2500
Yes.
Does it do it while sitting still? If so it has to be engine/tranny and not suspension/driveline. Although that would be odd that it doesn't speed up with RPM.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Does it eventually stop after it is heated up? Could be heat growth causing the noise but once up to temp should stop.
G
GENCOUPE16
Tn
No, I drove it an hour and a half home. And it did it the entire time. It's one of a few issues it's got...no power, running way rich, etc. But under a load it also backfires out the exhaust...
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Does it make the noise with the switch in RUN but engine not running?
It sounds like an actuator that is malfunctioning.
G
GENCOUPE16
Tn
Drove it an hour and a half home. Done it the entire time. It's steady regardless of rpm. Truck is really down on power as well and a strong smell of gas while driving. Gonna pull valve covers this weekend. Just never run into an issue like this.
G
GENCOUPE16
Tn
No it doesn't, it actually sounds like it's coming from the throttle body or inside the intake. According to my stethoscope...
There is a possibility, that the noise is coming from the HVAC system
it sounds like an actuator that is continually opening & closing a door.
although i have never heard one that is that loud
Try removing the fuse,
if there is no fuse for the HVAC fan & HVAC control panel
You might look at the front passenger side right foot kick panel.
I believe that panel conceals an electrical connector, that can be unplugged
Good Luck
G
GENCOUPE16
Tn
Figured it out hopefully. Collapsed lifter, exhaust valve. Pulled heads today.
jaccard30
