Laramie Interior Handles
R
rango10
If you work on your panels today, could you check the voltage between pins 3 and 9 with a multimeter if you have one?
I can check with my meter but it most likely won't be until tomorrow
Sent from my STV100-1 using Tapatalk
DeereGuy
Pittsburgh, PA
So I am convinced that my tradesman does not supply power on pins 3 and 9. I was trying to get it to work again today and still no luck. I noticed via the schematics for the C5 on the passenger side that pins 7 and 8 were the illumination feed and return for the switch so I depinned those 2 pins and plugged my harness into those two pins and bam I got lights. So now the question becomes is it the door controller or is it some code that needs flashed to enable it. Going to check my door tradesman controller part# against a Laramie and see if they are different.
00R/T
CT
There are only two different door control modules - with and without power folding mirrors. Next time I'm poking around in the BCM I'll see if there are any settings in there for those lights.
DeereGuy
Pittsburgh, PA
Thanks 00R/T. I've been considering buying the AutoEngenuity software and if there were settings for these lights that would seal the deal. :)
00R/T
CT
The only thing that concerns me is that I've never been able to get the door module settings to take (like the mirror ones). I'll do some experimentation though.
mdxers11
2013 Express Flame Red
I have to ask a question, perhaps it's stupid. My laramie panels, like the OP's have wires with a plug for the lighting, as do the LED bezels. Why would you cut the plug and either splice or build a custom harness for the door module? I am wondering why the plug is there in the first place? It must connect somewhere on Laramie models and if there is only two door control modules, where is it supposed to connect?
DeereGuy
Pittsburgh, PA
It is my understanding that the trucks with lights in the door have another harness that terminates into pins 3 and 9 of the doors C5 module. This is the harness that I have recreated.
00R/T
CT
Correct. It has a splice and splits to the two light connectors.
DeereGuy
Pittsburgh, PA
This is what my harness looks like installed before I connect the panels. The short connector goes to the door handle led and the longer one runs across and connects to the map light led connector.
Ram Man
FL
2013 Sport
Hope someone can help me out with an issue I'm having all of sudden...
The lights have been working flawlessly ever since I wrote the write up. I took the truck to the dealer to have my back up camera code flashed yesterday and now the doors don't illuminate. Any suggestion besides take it back to them??
*I have checked the fuses already and everything is okay
DeereGuy
Pittsburgh, PA
Wow doesn't that just suck!! I wonder if the flash updated software or changed settings in the BCM which disabled those pins from working. Welcome to my world!!
00R/T
CT
That would be my guess. For some reason that option was enabled from the factory but now that they updated it with the "correct" build configuration it was reverted.
This is why I'm reluctant to bring my truck in to get the puddle and signal lamps enabled.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
If I'm not mistaken, that's exactly what happened. If you want codes to stick they must be added to your build sheet.
Ram Man
FL
2013 Sport
Well, if this happens to anyone else, now you know.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I think it may have already about a month ago in this thread. I seem to remember someone asking why theirs wasn't working.
Ram Man
FL
2013 Sport
Dealer can't figure out how to turn them back on... can anyone give me a hand?
DeereGuy
Pittsburgh, PA
The only way I know to turn them back on is using a tool like autoengenuity to modify the BCM settings. It doesn't surprise me that the dealer couldn't/wouldn't turn them back on. The only thing dealers seem willing/able to do is add a sales code to your vin and reflash the truck. If the sales code isn't available for your vin, then there's nothing they can do.
Ram Man
FL
2013 Sport
They let me go back into the bay and check out the witech system they were using to communicate with the truck. Like you said, all they could do is choose from a list of sales codes to add or remove (based on VIN/build sheet I guess) or do random things in the BCM like reflash TPMS sensors and disable remote start.
Unless there are other screens that they need to go into... Man this blows
Rth_2
I just got a set of 2013+ laramie door panels for my 2012 slt.. how could I get these leds to work in my truck I just look in my doors and I don't have the same PIN numbers as u guys do
Nixonjgreg
