Lashing ?
ramhunter9
P-Star Jeep Wrangler
Explain in detail this job and why it is needed at 150k.
How do you know you need it and what is the cost in it ?
the codes
Houston, Tx
Magnum 5.2
I don't own a CTD but interested in the answer! seems like good info to know.
Stangshcky12
Oshkosh, WI
5.9 Cummins
It's the tolerance between the rocker arm and top of the valve
After so many miles it becomes out of spec, I've never adjusted CTD before but any of the motors I built you just use a set of feeler gauges on top of the valve and adjust till your in spec
the codes
Houston, Tx
Magnum 5.2
Iv seen em do it on horsepower tv before but never knew why
ramhunter9
ramhunter9
Is there a power difference or different feel after adjusting them
rambob
LA/MS
318 5.2l
I sent an email to my dad. I'll let you know what he says. I believe I have told you, he used to be a diesel mechanic.
but I dont think the performance changes, just that they can make noise when out of tolerance.
the codes
Houston, Tx
Magnum 5.2
on horsepower I think I remember them saying if it's not done right the timing can be off and cause perfoance issues? not sure
Stangshcky12
Oshkosh, WI
5.9 Cummins
You'll see a tiny bit of performance. Maybe better combustion and ignition definitely less noise
A big thing is that if it gets to far out of tolerance you could bend a valve
badfish888
Va beach
2012 hemi express
Dave are you talkn valve lash?..........our cummins 903's on our old boats got done every 5-600 hours, helped to make full power, bout 200rpm increase, helped alot with smoke control to, or injectors were also run of the rocker arms. not sure if that helps at all, but at 5-600 hours, 5 out of 8 cylinders would be out of spec, and theres 4 valves per cylinder in those
ramhunter9
ramhunter9
Anyone have a how to on this ? Got me curious
txbass06
NE Texas
5.9 Magnum
Here's a quick vid I found Dave
[yt]GLi03bG4zAw[/yt]
Uncle Ugly
Yes there is a difference in power before and after a valve lash is done.
Mine on all my trucks get done every 25k,no matter what the year truck is.
Its a simple job with the right tools and can be done in an hour once you have done it a few times.
Here is guide to go by and I know it shows a 12v motor but is the same on all the 5.9s.
B Series Valve Adjustment
rambob
LA/MS
318 5.2l
I know you got your answer. But my Old man said its mostly a noise thing, slight performance gain may be noticed.
Bettula
