That’s the one I got after reading your review, haven’t needed to use it yet.
My 2004 Lexus RX330 has a set of Lexus cables. stowed in the rear well, along with the spare tire tools. It has it's own bag, and the cables are very high quality. I'm still likely to use my jump box, which is barely larger that the iPhone 14. This box will start anything not diesel.I’ve had a NOCO GB150 for about 5-6 years now. It fits into one of the floor bins in the back. It has always worked for a low battery, usually after I’ve listened to the radio for a long period of time, the voltage gets too low. Even on my 2018 Limited 2500 Cummins truck, which had 2 batteries, it would not turn over once the voltage got too low.
Only once did the jump pack not work starting a CAT extendable forklift. When you connect the jump pack, it shows the voltage, usually reading in the low 11 volt range. In the case of the CAT battery, it only showed like 10.2 volts. I thought that was odd. Normally it doesn’t take too long to restore the battery enough and it starts, but in this case, it wouldn’t work. I left it on maybe 20 minutes. It turned out that a cell in the battery was bad. Replaced battery, problem resolved.
These jump packs are really convenient and I will always keep one with me. No more trying to get close enough so the jumper cables reach! And untangling them!
Ah! Yes! Electromotive pressure! (voltage) It is one of the times in physics where "More is better" applies. (to charging speed!)I have a Noco in each vehicle. I check them every 6 months or so. You can charge them right from the outlet in your pickup while you are driving, though 110 is faster..
Nothing wrong with having cables in a pinchI still got cables in everything . Guess Im one of the few who still has hope for humanity. lol. But at least after reading this post I’ll know which pack to buy now
Humanity aside, I've had to repair several vehicles where the owner (my customer) was a Good Samaritan and gave jump starts to folks stranded in say, the grocery store parking lot with ice cream melting, milk going bad, etc.I still got cables in everything . Guess Im one of the few who still has hope for humanity. lol. But at least after reading this post I’ll know which pack to buy now
I kept my cables too, but now they are just for my truck as a backup, if my jump box won’t work for someone I am trying to help, I’ll recommend they call tow truck.Nothing wrong with having cables in a pinch
The days of driving a boost vehicle up till the front bumpers touched and using a piece of barbed wire scrounged out of the ditch to boost another vehicle are long goneHumanity aside, I've had to repair several vehicles where the owner (my customer) was a Good Samaritan and gave jump starts to folks stranded in say, the grocery store parking lot with ice cream melting, milk going bad, etc.
After the dopamine wore off the doing a good deed, and their own vehicles suddenly having weird malfunctions, and they brought the car in, and they find out that the jump start cause the body control module to fail in a spectacularly strange way (windshield wipers would not shut off, at all, even with the key removed!) in one case. This repair cost my customer close to a grand. After I told him the whole thing about cables, and the wisdom of the jumper box, he became a believer.
On one car, my customer brought the car in because the low beam headlights didn't work. That just COULDN'T be both bulbs burned out, she exclaimed. The other symptom was that EVERY light on the dash was lit up.
My query to her revealed that she had given a jump start to a stranded person at the Kroger's, nearby, and that the troubles started immediately.
I found her charging system to be charging 21 volts! And, both low beam bulbs WERE burned out.
The ground wire on the instrument cluster had melted!
A new alternator, both low beam bulbs and a shunt ground installed onto the IPC cured her problem. Her bill was about 800 dollars. For a good deed!
Although I DO have a set of cables, I insist on the small jump boxes I own. The cables require a 20-30 minute window to use PROPERLY. In today's world, 30 minutes means death to many people!
Pax Vobiscum!
I had a buddy's car go dead when he went into Target last month. Working out of town and forgot to bring my jump pack with me. Offered to try to jump his car, which was a couple year old Acura SUV. My car couldn't get it jumped even leaving cables connected for 20 minutes. Finally called a tow truck and the guy tried his jump pack and it fired up after a couple tries. I'm just not sure cables are enough to jump the modern electrical systems in some cars.I still got cables in everything . Guess Im one of the few who still has hope for humanity. lol. But at least after reading this post I’ll know which pack to buy now
I interesting read ! I am curious about the 20/30 minute window you mentioned !Although I DO have a set of cables, I insist on the small jump boxes I own. The cables require a 20-30 minute window to use PROPERLY. In today's world, 30 minutes means death to many people!
It's usually due to improper contact of the cables. You have to insure 4 points of contact are clean and tight where as with a jump box you only have to insure 2 are and it's usually easy for them to dig into the lead.I had a buddy's car go dead when he went into Target last month. Working out of town and forgot to bring my jump pack with me. Offered to try to jump his car, which was a couple year old Acura SUV. My car couldn't get it jumped even leaving cables connected for 20 minutes. Finally called a tow truck and the guy tried his jump pack and it fired up after a couple tries. I'm just not sure cables are enough to jump the modern electrical systems in some cars.
