Leaking fuel from fuel line/ fuel rail connection
870master
5.9 v8 360
to start, i have a 1997 ram 1500 5.9 v8 360
recently i have been experiencing some fuel leakage coming from the fuel rail/ fuel line connection. the rail is plastic, the line is metal and had 3 o rings on it (2 blue, one black) currently to solve my problem, i disconnect the fuel line from the rail via a quick disconnect clip the slides down and over the line. then slide the line in and reinstall the clip.... that stops the leaking
ive noticed if i wiggle the line it will spray gas, or if the line is pushed in too far it will spray gas. im not really sure what is goin on here. has anyone else experienced this?
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
If you live anywhere cold it's likely the plastic has become hard over time. In combination with the rubber gaskets slowly hardening, you are looking at age related leaking. Replacing the fuel rail and rubber o-rings is all thats needed to fix the problem. Plastic will have the same problem again in 10-15 years if its new, if used it may not fix it at all.
Metal really is the way to go, i'd still replace those o-rings though.
870master
5.9 v8 360
thanks for the suggestions, i replaced the black o ring before so i really do not think that is the problem. ill look into getting a metal rail. if im not mistaken, the metal rail have a different fuel line connection too, correct? my fuel line is the male, and my rail is the female connection.
870master
5.9 v8 360
and i live outside chicago, so it does get pretty cold in the winters
Herefishy
