LED Fog light pods REVIEW / INSTALL PICS
firemedic10584
Central Fl
Hey guys,
Well, the damn mod bug bit me again. This time, the project was to pull the stock fog housings and HIDs off the truck and replace them with LED pods.
Like most all of us, money is a big factor on our mods.
Now, when it comes to LED lightbars/pods...we all know the Rigid is the top of the line. But, damn they're expensive!! I know a lot of you will say you get what you pay for...but I did A LOT of research before making this purchase and came to the conclusion that Rigid lights are damn there identical to most other "china crap" lights. Yes, they modify a few things and slap their name on it, but that's about it.
Well, I did more research and stumbled upon some forums where some guys were running Sidetracked Offroad LEDs. All of them had nothing but good things to say after running them for over a year. So, I looked up the company and looked around at some of their products. Well, they certainly seemed to be quality products and the prices were definitely right for a "want" project/mod. I even called them to speak with them about a question I had and they answered immediately and the guy I spoke with seemed very knowledgeable about the products. So, so far I'm impressed. Well, for the 4 LED pods I needed for this project, it came out to about $150. So, what the hell. I pulled the trigger. I ordered them on Friday and they arrived at my door Monday (from California to Florida). So on to the pictures and more review -
They came neatly packed and here they are opened up -
The connection point seemed of high quality and proper heat shrink used.
The connection from the light -
Here's the plug that plugs into the light and the other end you wire up to however you plan on powering the light. In my case and probably yours - I ordered 9006 male plugs off Ebay to wire on the end.
Here's how it looks when done. 9006 male end wired to the end of the plug. Soldered the wires together, heat shrink, then wire loomed.
All 4 of the connections done -
To be able to run from the stock wiring on the truck to power two lights, you need a 9005/9006 splitter. Also off Ebay. Here's what it looks like wired up-
And here's a teaser shot of the lights in action -
I'm waiting on the brackets to come in. Which for those of you wanting them - here they are.
ICI LBKT030DG - Shop RealTruck.com
All in all, I've only got 200$ in this project. Which is way better than 500-600$ in my opinion. Feel free to comment or ask any questions you have...I'll answer them as best as I can!
F
firemedic10584
Central Fl
Also, two of the lights are a spot beam and the other two are flood beam. One spot and one flood on each side of the truck once they're mounted.
Andrew09HEMI
Awesome man! Looks like the route I want to take eventually. Looking forward to the completed install
Synister
Columbus, IN
6.7L Cummins
This is a sweet mod. Looking forward to seeing the final pics. If possible can you do dome nighttime pictures showing how well the illuminate?
F
firemedic10584
Central Fl
Yep. I took them out last night and hooked them at to see how there were. BRIGHT AS F***! Better than the HID bulb I currently have in my fogs. I'll put up some action shots of them once installed.
LaKing
did you buy a spot and a flood for each side? also did you hook it up a load resistor to the wiring harness?
Tyrant
'12CC / '15RCSB
Did the same combo on my truck (1 Flood and 1 spot per side).
LaKing, no need for any load resistors, at least my 2012 didn't need it. I just hooked them up like firemedic did.
F
firemedic10584
Central Fl
Yep, one spot and one flood for each side. No load resistors. No need for them.
Yep^^
F
firemedic10584
Central Fl
Lights are installed and bright as f***!! Pics in about an hour once I get home.
F
firemedic10584
Central Fl
As promised - Brackets fit perfectly. Hardest part was just adjusting the lights so they were straight and even on both sides (my OCD would drive me nuts if they were not the same angle or spacing on both sides lol). I'll get some night time shots tonight. The top pod looks yellow from the flash of the camera. There's no yellow in them.
Here's the bracket mounted up -
The lights off -
Shot of both on -
Camera was pretty much straight on with this shot -
Addis daddy
Levittown
Dude that looks awesome. Do you think those brackets would work on a 2012? And did you run a separate switch for them or hook into the factory switch?
blackbetty14
CT
Hemi 5.7 VVT/Etorque
Love it, get some nighttime shots for output. Stock housings with HIDS don't do much. Thought about swapping in a projector but these fit the stylend better.
F
firemedic10584
Central Fl
Nope, just wired them so I can plug right into the factory plug. And no, these brackets will not work on a 2012. U need the Rigid brackets for the 2500 trucks...those will also work on the 1500's.
Output is pretty good. I need to adjust them to make the patterns a little better. Here is a crappy cell phone shot of just the fogs on.
Addis daddy
Levittown
Thanks for the reply man! I'm gonna be ordering mine today. What all did you need to purchase to make the factory switch work? (Sorry for all the questions)
haybale
North Texas
Very nice mod! I've been wanting to add some LEDs, but not sure which way I want to go yet. I might have to do this before adding a bar. I still have all stock bulbs, so anything will be an improvement!
Are those little single row led bars in place of tow hooks? If so, I've never seen that, pretty cool!
Any chance you could get another output shot with everything on but headlights? Just curious.
F
firemedic10584
Central Fl
Go back to the beginning of this thread. Everything you need for this install is listed. :)
The single row LEDs where the tow hooks should be are Philips LED DRLs 8.
shanmccarthy
