LED HeadLights
Justin Rogers
Austin TX
I have a 2006 Dodge Ram. I bought Led Headlights and plugged them in. The problem i am having, when car is NOT started up and lights on Low and High beams work, BUT if i start the engine, the low beam flickers and turns off but i can still position my high beams on and they work fine.
Thoughts on what i should do to fix these LED headlights?
DomCard
Las Vegas, NV
5.7L
you need a set of resistors. If you look on amazon you can find ones with a harness or just plain 50w 6ohm resistors from autozone
joshhhh
