Led help
tommyboi87
houma louisiana
5.2 Magnum
Ok guys, I must not know how to use sbl website or something, because I can't find anything for my dash. Can somebody please help me find the lights for my gauge cluster, climate control and headlight selector? I'd really really appreciate it.
Sent from my SAMSUNG-SM-G925A using Tapatalk
MagSport
South Carolina
For the gauge cluster main lights, a bulb with a t10 wedge base will work. I got mine on eBay with sockets. As for the hvac and light switch panel, there is a write up in the diy section that has the information.
MagSport
South Carolina
P.s. For the t10s make sure they are flat facing, not the "tower" style.
tommyboi87
tommyboi87
houma louisiana
5.2 Magnum
T10 wedge base'.. got it. That's for all of them?
rammanriley20
iowa
1999 Ram 1500
5.9 Mag
SBLs website ****** me over, every single interior LED in my truck (map lights, glove box light, ash tray light, dome light, etc uses the bulbs that are flat on the end) but the SBL website says that the map lights use a tube shaped bulb and that the glove box uses a bulb that's round on the end and I ordered them all and only a couple of the bulbs actually fit...
Sent from my XT1096 using Tapatalk
MagSport
South Carolina
In the cluster I mean
No just for the gauge lights and turn signal lights. Warning indicators and the high beam indicators use a different smaller bulb which, iirc is a pc094 or something like that. That info is somewhere on this site as well lol.
MagSport
South Carolina
Your's is a 99+ right? Pretty much all of your lights except for some of the gauge lights, hvac panels, and light switch panels, will accept and work with t10 base leds.
rammanriley20
iowa
1999 Ram 1500
5.9 Mag
Every one that I am looking to replace has the wedge base, their website says otherwise
MagSport
South Carolina
I replaced my cab light, map light, ash tray, cup holder, glovebox, turn signal indicators, 3rd brake light, and main gauge lights with T10 bulbs all working.
rammanriley20
iowa
1999 Ram 1500
5.9 Mag
Yes, those are the ones with the flat bases that slide in. That's not what their website has listed and sent me
tommyboi87
tommyboi87
houma louisiana
5.2 Magnum
That's my problem. Every light I bought didn't work. Was either too big, or had a different connection all together.
