Led Interior lighting
vtdodgeboy
5.2 Magnum
I have 2 strips of green led to match the color of my truck and i want to install them underneath the dash. I want to wire them into the dimmer switch so when i open the door they come on along with the dome lights. The dimmer has the a stop just before it turns on the dome lights where all the dash lights are the brightest thats when i want them to turn on when the door is not open. But I want to be able to shut them off not dim them. Kinda confusing not a wiring pro but know what most of the stuff is.
PCA4208
Albuquerque, New Mexico
You just need to find a wire that leads to a light that dims when the dial is turned. I think the radio should dim, or the ac/heat controls should dim also.
You can take off the radio bezel, or look in the owners manual to find what color the wire is that you want to tap into.
Crapo85
