Cherry Ram
Took it to dealer said there is a short between the BCM and the domelight . 1400.OO find it ? They said dashboard would need to be removed . Anyone help ? I checked bulb and replaced both had continuity . When i roll the dimmer it briefly flickered . Open door no lights dome , map or floor boards . Yet i can turn on map light manually . Everything else is working as it should . Even replaced dimmer control and returned it , did the same thing . Thanks for your time Don
