LED overhead console light swap
snakepitt1
Lake View, Alabama
2007 1500 4x4
Changing from the stock incandescent bulbs to LED's is a fairly easy and quick swap. I've done it now 3 times. Why you may ask have I done it 3 times? Well, I'll tell ya... After popping out the lenses it pulling free the burning hot bulbs, which managed to allow me to invent new and colorful words, I installed a set of superbrightled.com LED lights. They were much brighter than stock and didn't have that yellowish glow. Now when I pushed the switch to shut them off, they continued to have a slight glow to them, almost like there was a trace of power still going to the fixture and would just cause the LEDs to illuminate slightly. This effect would fade out when the engine was not running. But, with the engine running, the slight illumination would never go away. My wife calls it "mood lighting" I call it annoying. Any tips how to have LEDs in the console lights and not have to buy a mood ring to go with the mood lighting???
Skeer
Big Sky Country
2002 Ram 1500 4x4 SLT
I see you did not get a single reply here. Sad. If it was me I'd try adding some resistance. Say 100ohms and go up until the glow is no longer present.
jjantz2000
I just went to radio shack and bought a pack of 2 1-Watt carbon resistors. Fixed the slight glow in my LED's.
Superbrowndude
04 Ram 1500
I haven't had any issues with glowing from my Leds. I guess I'm lucky!
Hatcher1105
hey guys just my random thought here. But I would assume that the people who are having the slight glow issue probably have ram's that are a little older, and the guys who don't have a glow issue have the newer rams. I think whenever they started using the headlights with the LED strips they must have some different wiring??? Anyways that's just my random thought. Anyone know if I may be right??
blackbeautyhemi
Lewistown, PA
Mine didn't have leds til I started adding them. Now everything is switched out to led and still not one issue.
