LED running board lights
chevman792001
superior wi
I installed the lights and wired them up from the puddle lights and blinkers in the doors. The blinkers work fine and the white light comes on with the puddle light when I use the key fob. My problem is, when I open the door to get out of the truck the puddle lights and LED strip flash. Anyone else experience this? Is there a fix?
mrack
Did you use a relay? If not then add one, that’s way more draw then the puddle light circuit should have on it.
C
chevman792001
superior wi
No I did not add a relay. I could add one (two actually, one per side). Or I might just tie it into the floor light so they come on only when the door is open. But I am still confused as to why they work perfect with the key fob, but not when I open the door.
Vic2025
Where is the wire for the puddle lights and what color is it
DJack
