LED swap issues
Azbr06
So I have a 2017 2500 and I swapped my bulbs to the Fahren high and low beam LeDs. My issue is the shine off to the passenger side. I know I can adjust up and down but these seem off to the right. Both bulbs are clocked to the 3 and 9 position. Just doesn’t look right and is annoying that the passenger side is lit up and not drivers. Hope you can tell in the photo. Thanks for any info
mtnrider
Georgia
Reflector or projector housings?
Hemi395
Cape Cod MA
Did you get the passengers side headlight fully seated into the ball socket? I did that once and it was way off....
A
Azbr06
It’s reflector. And yes I believe I did get it fully seated. The bracket where the lower bolt goes is broke not sure if that is making a difference. The top bolt is good but no lower bolt.
thoffmann517
