Left led tail light shows out on dashboard but works
craigh4690
Moses Lake
2013 3500
I did an obd genie for LEDs 2 years ago and everything was fine until last week.
Dash shows issues with left tail light and flashing fast on the dash but actually flashing normal. Switched left side with the right side same issue which tells me it’s not the tail light it’s self.
Suggestions???????
C
craigh4690
Moses Lake
2013 3500
Suggestions???????
A_mod_too_far
Colorado
I have an issue like that that's randomly intermittent that I believe to be a grounding issue, but havent put in the effort to locate it yet. In my case I believe it is internal to the tail light though, but if you're motivated check the ground wire and also at the repeater in the mirror.
dougbobo
Stanwood Washington
6.4L Hemi
Did a full LED conversion to my 2015 Ram 2500 Laramie with projector low beams. All work but the low beam lights are dim, like half power or so, when just they are on. When I turn on the high beams the low beams double brightness WITH the high beams. Shut off the high beams and the low beams dim back to half. I’ve never noticed this with the halogens, seems only since conversion. Also, no flicker, no bulb out messages, all seems perfectly well other than this dim low beam situation. Am I missing something or any ideas of the cause?? TYIA
MB_RAM
California
V6
I had this problem after replacing my LED tail lights with aftermarket (2020 1500). "Left turn signal out." It was driving me crazy! It "dinged" and the dash lit up nearly every time I hit the brake. Everything worked perfectly, but the warning was going off and I'd get hyper blink inside for 2 months. Dealer told me there's nothing they could do. It was bc the system didn't like my aftermarket tail lights (voltage blah, blah, blah). I was desperate!
SOLVED... I was low on fuel. the "Low fuel" warning light kicked on. "Left turn signal out" light stopped. I was afraid to refuel, but of course I eventually did. The warning never went off again. I don't know why, but I'm telling you that's what happened. Give it a try!
OTownRam
