Level kit 2017 ram 2500
hollywood281
Houston
Add both links - price is about the same . If you guys could help me put it would be much appreciated . Truck currently has about 70k miles with original bilstein 4600s
Which one would you choose and why ? Essentially main difference is obviously brand name and one has coils vs spacers . I believe the Fox shocks are better but will I get a better ride if I switch out coils
Thanks
https://usdieselparts.com/i-24069945-2-leveling-kit-fox-shocks-2014-2018-ram-2500-4wd.html
https://www.bilsteinlifts.com/shop/...5100-0-1-rear-lift-shocks-14-17-ram-2500-4wd/
G. Mcpherson
Vancouver, Wa.
2023 Ram 2500 CC SB Tradesman
Look at Thuren Suspension Technology. Coils and Shocks will provide a much better ride for sure.
mtnrider
Georgia
I prefer coils on these trucks. Thuren or Carli are a good choice for a better ride but might not be a good choice if you are hauling heavy or running a drop in bed camper so keep that in mind. If you just want a better ride go with those.
I have the Bilstein on mine (next model up) because I did not want to sacrifice tow/haul capacity and it's been fine, no complaints.
H
hollywood281
Houston
Thanks mtnrider. Now when you say sacrifice tow/hauling capacity what exactly do you mean . I don’t see myself getting a 5th wheel camper . Just haul a travel trailer no more than 8-10 grand possibly . Or are we talking a serious load. I will have the factory springs in the rear which seem to be great. When I hitch my boat (4K lbs) they don’t seem to even drop at all . Please elaborate if possible I appreciate it
Donnie Straps
I have the Carli kit on mine with Fox shocks on all four corners. I have factory rear springs and I added air bags because I do haul heavy with my truck and didnt want it to sag in the backend. Rides great.
Sloverado
I have the thuren springs bilstein shocks and it’s perfect for a hd truck
mrfix1
US
6.4 hemi
has any one got some Measurements of the rear spring spacers.
i am looking for the outer diameter and the center hole Diameter
Sent from my SM-N975U using Tapatalk
