Leveling kit opinions
Jamcousi9
5.9 magnum
Howdy..
I'm thinking about doing at least the 2.5 inch front leveling kit by Rough country however I notice that some trucks actually sit higher by a hair in the front than the back afterwards, is this because of the rear suspension squatting from normal wear or are some front leveling kits to high? Rough country also makes a 2.5 leveling / lift kit which includes front coil spacers, rear blocks and new shocks however I'm not trying to lift the truck at all, just level it. The front spacers are 100 bucks and the whole 2.5 lift / level kit is only 100 bucks more.
What have some of you guys had the best results with?
rut1095
Central Va
Yep, It has 1
Not sure what generation you have, but here is my old 2013 with front level only. Didn't need the blocks for the rear.
rut1095
Central Va
Yep, It has 1
^^^^not really the best picture. Sitting on an incline and didn't notice what pic I used until after I posted. It leveled out fine. Can't remember the measurements, but rear was 1/2in taller.
wiram
Sparta, wisconsin
hemi 5.7, 5.2 318
Measure to the top of your wheel wells and add the lift hight and that should give you a good idea.
Sent from my SCH-R970 using Tapatalk
Reticle918
