Leveling kit without voiding warentee
kickinkid529
Hate the raked stance of my 08 sxt 4x4 but want to keep my warentee any ideas
jdeere05
Indiana
Hellbent steel
Will installing the*Dodge Ram leveling kit*affect my factory warranty?
The dealers in our area have told us that the kit does not affect the warranty because it is a bolt-on application and the customer could just remove the kit if a warranty issue arose. However, we cannot speak for DODGE. We recommend that if you are concerned about this that you check with your own dealer so you have an exact answer from Dodge
jwheeler
Washington
Not the whole warranty. But if you have a leveling kit and have problems with cv joints it might not be covered. It is up to the dealer.
Trenton
Any lift you install will void ball joint tie rod and cv joints if given the chance. it will not void trans or engine however larger tires than the largest factory tires can void those things. All of this is true if you do the work or have a independent shop do the work. Some may honour it or may not depends on how much you spend and are a regular customer that they want to keep coming back. On the bright side if its dealer ordered and installed they can not argue about the warranty coverage.
