Lifted with stock wheels.... post em here!!!
yortnodnarb
Adrian,MI
Yeah Shadow, are you planning the 1.5" zone body lift also?
Thats where i am really stuck... LOL its hard to tell if it will look funny with stock 33's....
the guy i quoted above was running 34's with 1.5' body lift and a level i believe, so not quite same as my bils are at 2.8
i have a feeling it will look fine... but i am going to order the carven progressive first LOL
If you max out the bils plus a 1.5" bl I think you're going to look a little goofy with stock 33's. 33x12.5 with some offset to get them outside the wheel well maybe, but I would say 34's minimum if not 35's.
Outdoors76
CT
The body lift is on the wish list. We'll see how things go. Maybe I'll add it when I add tires.
I guess we ARE in the same boat LMAO..
I may buy it and hold onto it until tires also.
it is muffler time lmao
Outdoors76
CT
I try to visualize but its hard to do.
I think it would look like a stock 2500 or stock f250 their tires do look a little small IMO
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
I did that first. congrats on the new muffler :)
Outdoors76
CT
thanks!
if i have time when i have the BL kit in hand then i will install the kit and see what it looks like and take pics.
thats the only real way to tell.
if it was a 3" body kit i think for sure needs 35's without question...
shadowhawk
Southeast WI
I like my stance now. I don't have the $$ for a 4" suspension lift, so the best I would do is the 1.5" bl. I agree though, that I should probably run 35s when I do that.
bigred74
Illinois
1999 and 2017
5.9L Magnum and 5.7L hemi
I'm only gonna be running 35's with my 6in lift which will actually be a lil more than 6in with the bils up front
Nastorino
CT
2015 2wd 1500 CC on 4" CST lift kit
Factory 20" Big Horn Wheels
No spacers
37x12.50x20 Ironman M/T
**don't mind the dirty fogs, they get dirty inside when submerged LOL**
Man than looks awesome! Bright white FTW! My bilstein 5100s are being installed as we speak. If I don't let them this would be my new goal. MY highway commute would mean A/T's not M/T's for me.
Outdoors76
CT
i have same issue thats why i stayed with wrangker duratrac and they wear like steel. well over 50000 miles in them
Lifted2wd
C
Cant wait to see end results. Im lucky my commute is about 25 miles round trip no freeways. Did for a week have a 70 mile round trip, tires did great on that too
Nastorino
CT
I'm gonna go with Terra Grappler G2's. Bilstein 5100s just went on today so I'll drive for a few days and let them settle before leveling. I'll decide tires in a couple weeks I guess.
Lifted2wd
How does the truck ride on 37s?
Truck rides really good. Smooth through the gears and I can cruise 65-75 no vibrations or issues with little road noise. I kept them at 45 psi
Outdoors76
CT
wow those 37's really fill up the well...
shadowhawk
Southeast WI
2015 outdoorsman
Bils set at 2.8
Zone 1.5 body
37/12.5/20 nitto trail graps
are you running spacers? I have a finder's width from uca to tire now, I can't imagine putting more tire on and not needing something on a stock rim.
yortnodnarb
Adrian,MI
A fingers width is a ton of clearance, you only need and 1/8" at most. That leaves you lots of room to go wider without issue.
mccjes55
