Lifting 2500 2wd gas truck
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
im lift shopping at the moment and 90% of what i see for 2500s is for CTD trucks, im curious if those would work on my 2500 gasser or not...
im thinking i want to lift the front level with the rear but just trying to decide on what method
17CrewCab1500
That is tough. The CTD stuff will be way to stiff for you on the ride.
I would make a phone call to Arron or Don on Thuren Fabrication and see what they have for you. If they don't have anything, I am sure they can recommend a product for you I am sure.
Ram-Rod
Missoula, MT
I've been having similar issues, considering a good coil based level (Don't want to use pucks) for the front of my 2500 hemi as well since I'm going to be pulling the front end apart to do struts and other bits soon anyway. Very hard to find coils for the gas trucks and I agree with 17crewcab1500 that the CTD stuff will likely be way too stuff.
Edit: Found today that Carli makes a 3in front level system for the Hemi, It's about $800
Demon-HeMi
Demon-HeMi
Houston
$800 for a level kit seems a bit high, does it come with a 40gal jug of lube
Lil_Ram
Power tech 3.7L
Maxtrac? Would a 1500 lift work since your a 2wd hemi. Still would be a spindle loft.
shanmccarthy
