Lifting a 2022 EcoDiesel
Warlock1
Buckeye, AZ
Eco Diesel
Hey Fellas need some input here.
For those running a zone or for that matter any 4 inch lift have you ran into front driveshaft vibration issues?
If so, what was your solution, custom driveshaft, shimming the diff, balancing the driveshaft, etc?
Anyone running a 6 inch lift have any issues?
What was your solution if any issues?
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Eco diesel requires a custom front driveshaft not 100% but I believe @Nick@GotExhaust can set you up with an Adam’s driveshaft
Nick@GotExhaust
Supporting Vendor
SC
Its definitely the driveshaft that is the issue. Its 4" shorter on the ED and lifts put it at too much angle. In MOST cases it causes vibration. Unfortunately we do not offer Adam's currently. We work with other companies that make driveshafts but they do not make anything for the RAM right now.
Warlock1
Warlock1
Buckeye, AZ
Eco Diesel
Hey Nick, can you find out from the powers that be (manufacturers, installers, purchasers) if they could measure what that angle is after the lift has been installed? It seems that a shim could be made similar to the 6" lift with just a few degrees added in to make a difference. I have access to some offroad fabricators that can not only make me a driveshaft but can also pretty much make anything. Thanks
Nick@GotExhaust
Supporting Vendor
SC
I can try. I would say a new driveshaft is the best option. If it was as simple as just making a spacer I am sure the lift manufacturers would of just done that.
Ecosqueasl
Ontario
3.0 Diesel
I have a 2015 ecodiesel, took a 4 inch lift out 2 years ago. It had a 1 inch spacer mounted on the end of shaft I remember, can't recall any shaft vibration until it went bad on me. Make sure your engine mount bolts are tight, that's what messed my shaft.
